Theft, broken slide rear glass, how to install replacement?
Old Aug 19, 2012 | 07:17 PM
ChevyMgr's Avatar
ChevyMgr: Ya got the wrong window.
bummer....
Old Aug 20, 2012 | 07:45 AM
kwe45919's Avatar
Sorry to hear you got broken into.......been there done that about 10years ago. They took the only thing they could.......nothing!!...hahahahahah.
Old Aug 20, 2012 | 08:03 AM
Zagohhr's Avatar
Pretty sure Zagohhr is talking about the little fixed vent window on the back passenger doors.
That´s Right ChevyMgr. I´m talking about the window that George is refering...Would you please share your wisdom with us to see how I can put a new one ?
Thanks!
Old Aug 20, 2012 | 08:21 AM
Zagohhr's Avatar
I´m afraid that probably the main intention was to steal my HHR. I had about 5 brand new CDs (With their plastic wrap) on the back that I recently purchased, and however he didn´t steal that...
Old Aug 20, 2012 | 02:32 PM
ChevyMgr's Avatar
Let's try this again.
Preliminary Procedures
1. Remove the interior trim panel. Refer to Rear Side Door Trim Panel Replacement .
2. Remove the water deflector. Refer to Rear Side Door Water Deflector Replacement .
3. Remove the rear side door window inner sealing strip. Refer to Rear Side Door Window Inner Sealing Strip Replacement .
4. Remove the rear side door window outer sealing strip. Refer to Rear Side Door Window Outer Sealing Strip Replacement .
1 Rear Side Door Window Bolt (Qty: 2)
Notice: Refer to Fastener Notice .
Tip
Loosen the bolts enough to let the window glass move free from the window regulator clamp.
Tighten
10 N·m (89 lb in)
2 Rear Side Door Window
Remove the rear door window. (see above)
1 Rear Side Door Window Outer Sealing Strip Screws (Qty:2)
Tighten
10 N·m (89 lb in)
2 Rear Side Door Window Outer Sealing Strip
Tip
1. Pull the rear window stationary seal from the pinch weld flanges.
2. Lubricate the rear window stationary seal to install.
3. The rear door stationary window is part of the rear side door window outer sealing strip assembly.
Old Aug 20, 2012 | 03:29 PM
Zagohhr's Avatar
Originally Posted by ChevyMgr
Attachment 13240
Attachment 13241
Tighten
10 N·m (89 lb in)
Tip
Looks clear for me now ChevyMgr! I think that I Should just follow the procedure above, not sure if I need to remove the moving glass from the first image. I just require to replace the door stationary window included on the outer strip assembly.
Thanks a lot ChevyMgr!!
Old Aug 29, 2012 | 10:10 AM
Zagohhr's Avatar
Glass replaced. Piece of cake, just took me five minutes. Thanks ChevyMgr for your guidance!
Old Aug 29, 2012 | 10:44 AM
Panels4Life's Avatar
Thieves suck!
Glad I got a Panel! Seems like those back windows are an easy target for thieves. But if someone wants to steal your car (or items in it) there are many ways to get inside the vehicle (even without breaking any glass). Bummer & sorry to hear this type of story.
Old Aug 29, 2012 | 01:27 PM
ChevyMgr's Avatar
Fue todo un placer.
bman4775
Sep 28, 2013 09:42 PM
windsmith
Oct 23, 2010 08:37 AM
Walt
Jul 6, 2010 09:32 PM
dknopp
Mar 23, 2010 08:31 PM
