Is there an actual ABS Relay in the HHR???
Old May 7, 2026 | 07:20 PM
chaosdsm's Avatar
One of the codes coming up on my Xtool D7X scantool is for ABS Relay - C0201-04, but I cannot find such a thing on the HHR? Is this something like the high brake light relay that's in a different place from most of the other relays??? Or is it just a generic description for the code & something else is causing it???
Old May 8, 2026 | 06:53 AM
https://fuse-box.info/chevrolet/chev...uses-and-relay
I see a fuse in the interior fuse panel
Old May 8, 2026 | 08:14 AM
That code is actually "ABS Enable Relay Contact Circuit". The relay is within the EBCM.
Here is a pdf from OnDemand:
c0201.pdf
My first thought would be a pin in the commector.
Old May 10, 2026 | 01:45 PM
chaosdsm's Avatar
Thanks for the PDF!!! Xtool D7X scantool just shows "ABS relay circuit". While the suggested fix is very similar to your PDF, the D7X was also talking about pulling & testing the ABS relay, and replacing if necessary. So I'm guessing that was more of just a generic repair guidance instead of being vehicle specific....
Old May 10, 2026 | 09:38 PM
PulpFriction's Avatar
How old is your battery? A weak on can cause a plethora of codes.
Old May 11, 2026 | 02:54 PM
chaosdsm's Avatar
Date code on it is Oct 2025, was installed new when I got the car in February. From what I've been seeing, it stays at about 12.6V with key on, engine off, headlights off.
Fievel4
May 28, 2024 07:54 AM
foltzkr
Dec 4, 2019 06:43 AM
canroc
Sep 18, 2014 04:29 PM
us11csalyer
17
Jan 23, 2012 07:38 AM
