Thermostat issue
Old Nov 5, 2020 | 01:45 PM
  #31
What is the manufacturer and part number of the thermostat you installed?
been documented here many times, these Ecotec engines only like the AC Delco 131-158 180 F degree thermostat.
https://www.chevyhhr.net/forums/how-...l-p0128-24493/
secondly are you sure you are burping any trapped air out of the cooling system? Very important to use only Dexcool 50/50 mixed coolant.
https://www.chevyhhr.net/forums/how-...-system-60614/
Please note megs posted way back in 2011
Old Nov 5, 2020 | 01:51 PM
  #32
If you keep blowing head gaskets, there is something wrong. Possibly a warped head or block, or damage to the mating surface.
And "keeping coolant in it" says, "coolant is leaving the system, and I'm topping it off periodically". Probably leaving through the poor seal at the head gasket.
Why was the thermostat changed in September?
munden
Aug 11, 2019 11:17 AM
questgraves
Feb 4, 2014 10:34 AM
Lucky
Dec 31, 2013 10:28 AM
06burntorange
Nov 11, 2013 12:32 PM
tracy waddell
Jan 9, 2011 10:49 AM
