Thermostat replacement
Old Sep 13, 2019 | 09:35 AM
KyMystikal's Avatar
I changed my thermostat with no problems until I went to put the housing on. One of the two bolts holes that tightens it down stripped. How do I fix it?
Old Sep 13, 2019 | 09:58 AM
A re-read shows you mean the housing it attaches to (You say the bolt is stripped - then you need a new bolt.) But I expect you actually mean that the housing that the bolt screws into is stripped? If that is the case, then it needs to be drilled out and retapped for a slightly bigger bolt.
Mentioning what engine you have would really help. 2.2/2.4 or 2.0 turbo?
edit: after looking at some documentation it looks like the lower housing for the thermostat is a bolt on item, and is separate from the block. A replacement will be available from GM.
Old Sep 13, 2019 | 10:16 AM
replacements for that lower housing:
(Without knowing what engine you have, nor what year )
https://www.ebay.com/p/2-4-Chevy-eco...Pipe/657164745
It's listed here as item number 8: (but no listing for it)
https://www.gmpartsnow.com/oem-parts...bC1sNC1nYXM%3D
Note at the bottom it states they don't carry every single part so contact your local dealer.
Old Sep 13, 2019 | 01:48 PM
Junk yards have lots of them. They "should" be cheap as they are made out of really cheap soft metal; almost pot metal.
Old Sep 13, 2019 | 02:58 PM
Welcome to the site, You could reach out to hellshotrod, he’s parting out HHR’s
Old Sep 14, 2019 | 01:51 AM
KyMystikal's Avatar
Sorry. I never thought to add the other information about motor size. I have a 2007 HHR LT with a 2.4 motor. I didn't know the bottom housing could be bought. I ended up drilling out the stripped bolt hole and running a longer bolt and nut through the housing.
Old Sep 14, 2019 | 02:42 AM
Good fix - and a whole lot cheaper than the housing replacement. Just keep an eye out for leaks for a few days and you should be just fine with it.
HannahsHHR
Maintenance and Upkeep
15
Dec 9, 2023 07:16 AM
Jpak88
Jun 9, 2018 08:58 AM
Smoke Wagon
"How To" Tutorial Library
148
Sep 6, 2016 11:29 AM
JCC
Sep 25, 2015 02:47 PM
