Tick at idle?
I believe someone who has the Service Manual for these engines indicated there is no way to adjust the valves/lifters. But he, and correspondingly I, could be wrong. So, if the noise is coming from the lifter, it (or the associated "train") would need to be replaced....if warranted.
I was wondering ... could it be a spark plug at the end of it's life? Yes, 44k is not a lot of miles for spark plugs, I know, but still, if it had a problem before you bought it, and ran rich for a while, that could foul the plugs up real quick.
I still also go with the valve lash adjusters or lifter/rocker noise, having the same problem with my Firehawk (although much more pronounced) but it can't hurt to try changing spark plugs/wires if you haven't yet, as that's a rather cheap and easy job to do.
I took it to the dealer where I bought it and the tech who did a ride along with me said "all of these engines make that noise, it's normal" so I guess I will find a different dealer to look at it.
I have a ticking sound that I can hear at low speeds and it's the injectors and is normal..... It's a higher pitch sound than lifters would be and very faint but it's there.
Try a different dealer, but it could be that tech is right.
tiggercross59
Sep 26, 2024 02:16 PM
ORGELBAU
7
Mar 12, 2012 04:12 PM
