Timing Chain change,
Old Mar 27, 2015 | 08:47 AM
Bunky's Avatar
Question Timing Chain change,
My 2007 HHR with 210,000 miles is making noise on start up, then is quiet I would just try changing the tensioner but with this amount of miles and no record of any previous change of the timing chain I feel it's safer to change the chain and guides as well.
I know about the Harmonic balancer bolt needing replaced,
So my questions are even though the gears are steel, should these should be changed as well ?
And does the timing chain cover gasket need to be replaced as well ? or can these usually be reused ?
Is there anything else I need to know ?
Old Mar 27, 2015 | 09:44 AM
At that milage yes change the gears and all related gaskets, and while you're at it swap out the water pump!
There are kits available with all the parts required included in the kit.
Old Mar 27, 2015 | 09:56 AM
Bunky's Avatar
Ok thanks I also had a reply saying the faster is only $7 that's the seal the gasket is $35.00 on the sites I priced . So I will see when I get it apart .
Old Mar 27, 2015 | 10:59 AM
Auto correct has me stumped.
The book says to replace the gasket and all of the bolts. Sometimes books are sales tools.
Good idea to think about the other chain and it's tensioner also.
If it's a 2.4 the variable valve timing stuff need extra care.
Old Mar 27, 2015 | 11:46 AM
Bunky's Avatar
I have a 2.2. And as stated in my post I'm.changing the timing chain. I can see the gasket but I didn't see the bolts listed. But will check into those as well.
Old Mar 27, 2015 | 12:05 PM
And change out the water pump and its chain
Old Mar 27, 2015 | 12:42 PM
I meant the camshaft sprocket bolts. Not the cover bolts.
GM tends to want you to replace most bolts over 13mm.
Old Mar 27, 2015 | 01:51 PM
09BLACKHHR's Avatar
Mine has 147*** when is the chain and water pump replaced not making any noise just to know
Old Mar 27, 2015 | 02:37 PM
I'm at 184,000 miles on my 2.2 '07 and 200,000 miles on the wife's '03 Sunfire GT, both are on the original chain and sprockets, no noise yet so I have no changed them out, yet!
I am considering the timing chain and the head gasket change just as a preventative maintenance measure! I want to avoid bent valves and damaged pistons.
dooscoop32
Jul 15, 2015 04:59 PM
RRAFS
Jan 14, 2015 08:47 AM
Banana hands
Apr 17, 2014 04:49 PM
fastsuv
Oct 21, 2013 08:12 PM
codered3232
22
Mar 6, 2012 09:01 AM
