Timing chain should do's?
Old Feb 4, 2022 | 08:01 AM
tsbrewers's Avatar
Hey all, my newish to me HHR is approaching 150k and as far as I know the timing chain has never been done. I have a buddy that is a mechanic that is going to help me do it, but I am wondering if there is a list floating around of "should do too" type things and also which parts or kit to use? I would like to start ordering things for when he is available, so I am ready to go.
So for example, I believe I read the water pump should be done at the same time? Do I need the water pump tool holder tool if I am doing it all at the same time? ( did already install the tensioner bolt/mod) Anything else?
Also is there is a brand of kit that most people recommend going with that has all the gaskets, chain, etc.?
If there is already a sticky, I could use a hint, I haven't been able to find it.
Thanks,
Old Feb 4, 2022 | 12:09 PM
There is a sticky,
https://www.chevyhhr.net/forums/how-...in-kits-60394/
If you take off the front cover, you do not need the water pump holding tool.
I suggest you change the serpentine belt and tensioner, both have worn and lost tension and the bearing is dried out.
Order the front guide bolt, Dorman or Melling are good
Order a new valve cover gasket set
Order a new front cover gasket and seal
At RockAuto we do get a discount
https://www.chevyhhr.net/forums/supp...-2022-a-61707/
The kit you want depends on the year and engine in your HHR
I also suggest a new thermostat AC Delco 131-158 180 F degrees.
And fresh Dexcool 50/50 mix
Old Feb 4, 2022 | 12:53 PM
tsbrewers's Avatar
Thank you, I'll check out that link and video. I have an '06 with the 2.4L. I didn't know if there is a certain aftermarket brand kit that was best, or if I should stick with OEM?
Thank you,
Old Feb 4, 2022 | 05:14 PM
Cloyes, they made the OEM as far as I know and in any case, I’ve used their timing chain kits for 50 years, never had a failure!
Old Feb 4, 2022 | 06:39 PM
And a new bolt for the crankshaft pulley is recommended.
Old Feb 4, 2022 | 07:29 PM
Lonwane's Avatar
I did mine with the Cloyes chain kit.
Don't use the Felpro crankshaft seal.
I did and it leaked.
I did use a Felpro timing chain cover gasket.
Order an ACDelco seal.
Old Feb 4, 2022 | 09:39 PM
tsbrewers's Avatar
Thanks all, so far I have in my RA cart,
GM GENUINE 11589123 crankshaft pulley bolt
GM GENUINE 24435052 timing cover gasket
FEL-PRO VS50769R Valve cover gasket
GM GENUINE 29616 crankshaft seal
CLOYES 94201SAWP Timing chain kit that Includes Water Pump (non-vvt? I believe my '06 2.4L would not be VVT?)
GATES K050400 Serpentine belt
DAYCO 89316 serpentine belt tensioner
AC Delco thermostat 131-158
I have already replaced the front guide bolt with one from zzperformance, so should be good there.
Anything I am missing?
Old Feb 4, 2022 | 09:59 PM
Your 2006 HHR 2.4 HAS VVT.
Old Feb 5, 2022 | 05:59 AM
tsbrewers's Avatar
Okay, I thought that started in '08 or something?
Old Feb 5, 2022 | 06:23 AM
You can read the whole article here: https://en.wikipedia.org/wiki/GM_Ecotec_engine
Screenshot from that article.
