Tons of P codes... help!
Old Jul 23, 2020 | 08:12 PM
My thought, and it's a long shot, is that a PO may have replaced a harness in the fuse block, with a harness from some other model(not HHR). That may explain why #33 is affecting the transmission.
Old Jul 23, 2020 | 08:44 PM
He was saying that the codes cleared after the fuse change. That is as expected.
If you remove that fuse the computer will stay in open loop mode, meaning that the ECM is no longer in charge. The transmission functions with no computer assistance, the engine runs like an old fashioned gas-guzzler in need of a tune up.
So, I would inspect the TCM connectors and wires. The typical way people destroy the TCM is by letting a hot wire touch the case.
I don't trust that youtube fix, for one thing it is not an HHR secondly there is a ground wire in the connector that goes directly to ground; if the youtuber was smart enough he would have checked for continuity from the TCM case to ground. And cautioned about getting that wire near a hot wire.
Old Jul 23, 2020 | 08:56 PM
Diego Ortega's Avatar
correct. The engine is running rough since it's not using the o2 sensors or maf sensor. I'm surprised the engine still runs without the maf sensor. I'm going to check ground g107 tomorrow. How would I test the tcm to see if it's working?
cturboaddict
Dec 27, 2019 08:43 AM
rbunton
Aug 27, 2019 07:24 PM
Scott Taylor
Oct 24, 2018 08:50 PM
cjmickel
Feb 4, 2014 06:18 PM
JRock
Jul 21, 2010 04:34 PM
