Traction control issue
Old Aug 25, 2018 | 10:32 AM
3 threads merged.
Old Aug 25, 2018 | 11:35 AM
What was the exact code? I doubt that it mean the sensor is broken.
If the code is C0252 the book says calibrate the sensor with a scan tool, if the code is still present replace the EBCM. It mean checksum error I.E.: needs calibrating or the EBCM is broken.
After the sensor is replaced it must be recalibrated.
A new EBCM needs programming.
Since you asked:
Old Aug 25, 2018 | 06:04 PM
Check your RPO code sheet in the glove box, make sure you have JL4 brakes.
Old Aug 25, 2018 | 06:33 PM
davidfr's Avatar
Why JL4 brakes
Old Aug 25, 2018 | 06:44 PM
Cause that’s the active brake system that uses the steering sensor
https://www.rockauto.com/en/catalog/...n+sensor,13497
Old Aug 25, 2018 | 07:16 PM
davidfr's Avatar
Steering angle sensor
My RPO code sheet has JL4 and JM4 listed.
Old Aug 25, 2018 | 08:11 PM
Ok then you have the JL4 code that’s the sensor you need.
Old Aug 26, 2018 | 12:12 PM
Except that it is not a bad sensor, unless you are throwing parts at it. Just because a part name is in the description of a failed OBD2 test does not mean that part is bad.
When you read codes you are asking the computer to tell you what test has failed. The tests have code names like C0252, which test a specific system; in this case it is testing the checksum of the EBCM in relation to the steering angle sensor. The checksum is stored in the EBCM and indicates when the steering is centered. If the steering has been off center the checksum does not match the stored checksum.
Please do some testing before you throw parts around. Most sensors are coils of wire, they don't wear.
vrg813
Aug 25, 2018 04:27 PM
Lee3333
Jul 13, 2011 08:51 AM
Money in the Bank
Oct 19, 2007 12:26 AM
Whichfinger
Jul 22, 2006 11:30 AM
Adogg9626
Mar 4, 2006 08:55 PM
