Transmission Box
The Problem is that am in Africa and there are not good mechanics who really know inside out of American vehicles. The car has been with so call automatic transmission expert for two months and they are doing try and error. When the vehicle is above ground and its on Drive you will see the wheels running very fast but, has soon as it gets on the ground the drive does not work.
You have an internal transmission problem. Torque convertor, clutch discs, partial stripped spragg gear or faulty pump are all possibilities.
You're going to need that expert to pull and rebuild the transmission.
The 4T45E transmission is very popular worldwide in many 4 cylinder GM cars, like Opel, Holden, Vauxhall and a few Asian brands. You might find a used one.
I am not any kind of authority on transmissions, but the first thing to check would be the torque converter then the valves & solenoids.
They should be able to figure it out easily, it is not an "American" transaxle. Automatics are pretty much the same anywhere.
This same issue happened to me just last fall. There is a tube assembly within the transmission pan and one of the tubes has become broken at an end. The pan must be dropped, the tube assembly must be removed and welded (instead of being brazed), and all must be reassembled with new transmission fluid. I changed the transmission fluid filter at the same time. Hope this helps.
