Transmission Noise
Transmission Noise
I have an '07 HHR with 64k miles, a 2.4L, and an automatic trans. This last week there has been a noise coming from the front end. It sounds like mud tires running on asphalt. My tires are new, <5k miles. I put the car on jack stands and the sound is still there. It is not brake related as there is not a change in the sound when brakes are applied. The sound is only present when the car is running.
I have seen this problem from a post a couple of years ago but there was not solution presented.
Please help if you know what is happening.
SL
SL
Have you checked the Constant Velocity (CV) Joint boots for cracks and tears? If dirt gets in the joints, it makes them noisy.
Another thing it could be is the bottom of the torque convertor cover rubbing on the flywheel or side of the torque convertor.
Clare
Clare
Last edited by cc732; Nov 15, 2010 at 01:19 AM. Reason: added torque convertor cover
HHR321
Feb 17, 2007 11:18 AM
