Transmission problem
Old Oct 22, 2019 | 04:15 PM
Myhhrsucks's Avatar
So I have a 06 HHR, 2.2 automatic. I bought it with high miles. Ran great. I noticed when I would take a sharp turn, accelerating, that it would rev up almost like it was slipping. I changed the filter and fluids, and about a week later I lost my D gear. It will not move in D. However, I can take off in I and at about 40 mph, switch to D, and it will keep going np. Since my D gear went out, I have maybe put 10 miles on it, and I've bought a replacement transmission already. Just really puzzled and honestly at a lose for what it could possibly be. Anyone had similar experience?
Old Oct 22, 2019 | 09:11 PM
Did you use DexRon V!? With the right amount 7 Qts/6.6 L.
Old Oct 23, 2019 | 07:59 AM
Transmission solenoids failed.
Old Oct 23, 2019 | 09:16 AM
If you want to find out whats wrong, have the codes pulled. Failing solenoids should trigger 1 or more codes.
FYI. That choice for your user name. Not the best idea.
Old Oct 23, 2019 | 09:31 AM
fastsuv's Avatar
The same solenoids are used for both D and I so I don't think the solenoids themselves are bad.
The owner's manual says that I mode provides more engine braking for slight downhill grades and also keeps the transmission from constantly shifting between third and fourth gear.
Maybe I mode provides more fluid pressure that is overcoming worn clutches/bands?
Steve
Old Nov 24, 2019 | 08:56 PM
hhr06NJ's Avatar
my 06 would shift hard to 2nd and 3rd, also shift hard at a stop into Drive and Reverse. Shut off for 5 min, start up and no problem,
did this for a month, about 4x.
then the other day engine revved like slipping.. I coasted to a stop. No D at all. Just Reverse. I drove home in REVERSE.
GETTING towed tomorrow .
I searched forum.
Bucket of Hot
Mar 19, 2019 09:05 AM
bad03xtreme
Aug 14, 2009 07:03 PM
camaro98z28
Jul 27, 2008 12:22 PM
mew7789
Dec 6, 2006 01:08 PM
DJ Koz
2.2L Performance Tech
11
Aug 21, 2006 11:58 AM
