Transmisson leak
Old Mar 9, 2025 | 02:32 PM
McFrodo's Avatar
Transmisson leak
Hi all I have a 2011 HHR with a Transmisson leak at this metal tube looks like it goes from the Transmisson to the engine its leaking on the engine side what is this? Probably going to have take this one to the shop I thought it was the cv axel seals replaced them still have a leak. TIA
Old Mar 9, 2025 | 02:38 PM
That aluminium tube? About 2” diameter? That’s the water transfer tube from the thermostat housing to the water pump. That has 2 orings on it and if you have a 19mm deep socket 3/8 drive and a 10mm socket you can charge the orings. First make sure it’s not the water pump leaking.
What colour is the fluid leaking out? Orange? That’s Dexcool. Red is transmission fluid.
Old Mar 9, 2025 | 02:48 PM
McFrodo's Avatar
Your right it is Dexcool not tranny fluid it feels oily. Thanks I will look into this
Old Mar 9, 2025 | 05:17 PM
PulpFriction's Avatar
How much is it leaking?
Old Mar 9, 2025 | 05:43 PM
McFrodo's Avatar
not a lot about 1/2 cup under the car in the morning
. going to check tomorrow to see if tis the pump or the pipe seal. If it the pipe seal, I will have a go at it, if it's the pump I'm going take it to the shop
Old Mar 9, 2025 | 06:25 PM
Bonez's Avatar
1/2 cup in the morning is a lot because under pressure while driving it has to be spewing out
Old Mar 9, 2025 | 06:51 PM
Gearhead1's Avatar
Leaking means air in coolant system which make pump cavitate…and not circulate….engine gets hot or hotter
Old Mar 9, 2025 | 08:27 PM
Are you sure that's the coolant transfer pipe? It seems to terminate right above the bolt for the flex pipe.
Old Mar 10, 2025 | 07:55 AM
Bad camera angle, RJ
https://www.rockauto.com/en/catalog/...mp+gasket,2148
The VR kit gives you the orings and thermostat housing seals.
Gearhead1
Jul 31, 2024 08:28 PM
Cameldog
Jan 7, 2020 07:40 AM
bcp1975
Mar 23, 2015 05:23 PM
pyro panel
Oct 12, 2011 04:53 PM
ericdraven
Sep 3, 2011 11:19 AM
