Trouble with DTC codes (long)
Old Oct 17, 2015 | 07:10 PM
I forgot to ask, have you replaced the fuel injectors #4 maybe clogged enough to cause your issues
Old Oct 17, 2015 | 07:32 PM
twistedjay's Avatar
I just picked up some CRC throttle body cleaner. I will get to work cleaning that and checking everything else suggested tomorrow. Thanks for the help
Old Oct 17, 2015 | 08:54 PM
Be very careful cleaning the throttle body - do not move the butterfly manually, as one can strip the gears on it, meaning a new throttle body will be needed. So a search for throttle body cleaning for some tips on it.
Old Oct 18, 2015 | 03:36 AM
Give this thread a read twistedjay...
https://www.chevyhhr.net/forums/how-...le-body-50000/
Old Oct 18, 2015 | 09:39 AM
I was looking for that , and you had it in your computer, thanks Mike!!
Old Oct 21, 2015 | 02:39 PM
twistedjay's Avatar
Update
After cleaning the throttle body (which looked very clean to begin with) I checked my codes again. Still had the cylinder 4 misfire code, along with two codes relating to the MAF sensor. I went ahead and bought a new acdelco sensor and replaced it.
Now when I run a scan I get the cyl4 misfire code, and p0201 and p0203, which are malfunctions on fuel injectors 1 & 3. I am totally stumped at this point and unsure what to do next. Wondering if I may have an ECM problem?
So far I have: replaced plug, coil, and injector on cylinder 4. Also cleaned the throttle body and replaced the MAF sensor. Any ideas would be greatly appreciated.
Old Oct 21, 2015 | 03:11 PM
Whilst you did all of this did you disconnect the negative cable at the battery! If not try an ECM lobotomy , and disconnect the battery negative cable for 30 minutes to rest the computers.
During that 30 minutes check all those connections .
Old Oct 21, 2015 | 03:15 PM
twistedjay's Avatar
I did that a few minutes ago. It cleared all the codes except the cylinder 4 misfire. And the service esc/tsc light return with a couple minutes of idling.
Old Oct 21, 2015 | 06:59 PM
Educated guess carboned up or burnt valve!
Old Oct 21, 2015 | 07:37 PM
twistedjay's Avatar
Not what I wanted to hear, but I'm afraid you may be right. I'm hoping rislone can work a miracle.
