Turn off content theft system?
Old May 25, 2009 | 09:57 PM
alw's Avatar
alw
I've lost use of the key fobs on a '06 model due to poor soldering on the fobs.
Until new ones are purchased, is there a way to turn off the content theft system? Every time I unlock the door with the key the horn alarm goes off.
Old May 25, 2009 | 10:43 PM
HHROwner's Avatar
try to resolder them. If it's around the battery holder.....I did it using a cold fusion solder devise and they have worked perfectly since. there is a thread on here (I beleive) that walks you thru the process. And if nothing else, they don't work anyway so it would not hurt to try.
See Jeff's post below for soldering the keyfob....thx Jeff
Old May 25, 2009 | 11:00 PM
Just manually push the lock(s) down while the door(s) is open, or lock the car using the key. This should not engage the Pass III system that the HHR is equipped with.
Old May 26, 2009 | 05:13 AM
Jeff®'s Avatar
Easy fix: https://www.chevyhhr.net/forums/how-tutorial-library-21/keyfob-cold-solder-repair-22641/
andoll83
May 11, 2009 06:59 AM
Wolfie
Jul 18, 2008 09:13 AM
itschaboykenny
Jun 13, 2008 07:43 AM
