Problems/Service/RepairsIf you have a problem with your HHR, want a tip on repairing or performing a particular service to you HHR here is the place to post!
Hey so I successfully removed the black box unit that has the lights/turn signal lever on it because I saw a video where they said that flipping a metal thing might help.
Next I took off the 4 screws. And I flipped the thing, put everything back on and it still doesn't cancel.
The white part on the right has to engage the cancellation cam in the steering column, that could be the issue.
Fixed it, thank you. The video did me no good turns out someone the white plastic thing you find when you lift up the whole spring mechanism was loose and kept slipping out of the spring. Just used a strong glue to keep it in place and it's all fine now.
