Valves Hit Pistons
Old Nov 21, 2020 | 09:24 AM
tr34's Avatar
Alright, so I checked it today and it idled fine when it was cold, no codes, but then once it got up to temp I got another pending code and it idled a little rough. I got a code different from last time though, which is now multiple cylinder misfire. I checked all the connectors and wires, no issues with that. Could it still be one coil pack, or could it be from reused insulators that seemed to be worn for the fuel injectors? I guess I'll start with the cheaper of the two and just order new insulators?
Old Nov 21, 2020 | 09:54 AM
If you don't post the actual code numbers, then it would just be a wild guess.
FYI. There is no code for "multiple cylinder misfire"
Here's the misfire codes listed:
P0300 Engine Misfire Detected
P0301 Cylinder 1 Misfire Detected
P0302 Cylinder 2 Misfire Detected
P0303 Cylinder 3 Misfire Detected
P0304 Cylinder 4 Misfire Detected
Old Nov 21, 2020 | 10:19 AM
tr34's Avatar
It was p0300, sorry. On my obd2 scanner it shows as multiple cylinder misfire
Old Nov 21, 2020 | 12:43 PM
P0300
have a read through this
https://www.obd-codes.com/p0300
check what is suggested in it.
Old Nov 25, 2020 | 03:32 PM
tr34's Avatar
Okay, installed the new seals today and still getting the pending p0300 code, but now I'm also getting the pending p0172 code as well. Could it be a faulty injector, or could it be the Vapor Canister Purge Valve Solenoid? I read on other threads that it could be that.
Old Nov 25, 2020 | 04:17 PM
  #26
P0172 would be either MAF sensor or fuel delivery problem, it could be the flex pipe broken, or low fuel pressure, have a look ...
https://www.obd-codes.com/p0172
Old Nov 27, 2020 | 10:51 AM
  #27
tr34's Avatar
I cleaned the MAF sensor today, didn't fix the codes. I was looking at the O2 sensor voltages, and the upstream one (B1S1) was fluctuating from 0.05v to 0.8v with 0 to -5%. The downstream (B1S2) was staying at 0.75-0.8v with 99.2%. Is this normal for the O2 sensors?
Old Nov 27, 2020 | 11:40 AM
  #28
Did you look at the flex pipe?
That’s it , the accordion part.
You can weld or clamp in a new flex pipe after you cut the existing pipe.
Old Nov 27, 2020 | 11:49 AM
  #29
tr34's Avatar
Yes, I replaced that about two years ago
Old Nov 27, 2020 | 12:07 PM
  #30
Cat Man HHR's Avatar
Oxygen sensors will fluctuate voltage if working correctly.
Do your homework on both O2 sensor voltage differentials.
