Violation function of the automatic transmission or something like that
Old Jan 20, 2012 | 09:42 AM
Grizzly old man's Avatar
I read a thread on here about cleaning the throttle body. As I recall some of the symptoms you are describing were attributed to that needing done.
Prepare for minor blood if you try to do it yourself.
Old Jan 20, 2012 | 10:06 AM
There are three possible things I can think of Andrey that might be causing the new symptoms.
1. As Grizzly suggested, a throttle body that might need cleaning.
2. An exhaust leak, especially at the flex joint behind the engine.
3. Contaminated fuel, either from the place where you buy it, or from condensation in the the fuel tank of your HHR.
Old Jan 20, 2012 | 10:33 PM
geg's Avatar
geg
thanks for the info.
1. I cleaned the throttle in August. Unfortunately, after cleaning i had problem with the software. Some with the engine speed. But the problem removed at once through the reprogramming of car's brain. I rule out the throttle.
2. I will inspect the exhaust system.
3. Problems with the fuel - it is very likely. A pair of *******s spend their policy so that the wholesale price of gasoline more than retail. It is unlikely that Americans will understand it immediately, or at least believe this - but it's true. Result, we have the gasoline's properties as donkey's urine. The worst thing you can not just switch supplier. All Russia has such gasoline or even worse.
Old Jan 22, 2012 | 02:57 AM
cpcook's Avatar
sounds like the prolem i had, replaced the timing chain and all is well.
see my thread on p0016 code
Old Jan 24, 2012 | 06:45 AM
geg's Avatar
geg
I read it (incidentally, a good record).
But my "check engine" does not bother me (yet). At the same time, I was horrified to think about replacing the chain - is too high costs.
When we started this conversation ..
You replaced the chain. What else do you replace at one time with a chain? Chain tensioner? Some of the gaskets and O-rings?
donbrew
Drivetrain (Excluding Engine)
22
Mar 3, 2024 08:06 AM
Lone Ranger
Mar 17, 2014 09:43 AM
donald cole
Jul 17, 2012 10:50 PM
sbishop1331
Dec 28, 2009 06:40 PM
JoeyFeduka
2.0L Performance Tech
13
Nov 5, 2009 07:50 AM
