VV & O2 Censor
code p0449 and p0139.
valve = $30, harness $36, Sensor $105 and labor $195.
I wonder if this is the norm ?
a quote of over $400 just for front brakes.?
It seems if you use gold or cheap brake parts they only last a year here in the north country.
thanks Link
thanks Link
Did you hold your hands up when you walk in the stealership ? Get your own parts and fix it yourself ,I am sure you will get a lot of help with your problem here ,anyway the code for vent valve is when your filling up with gas and the pump clicks off ,do not push more gas in it ,this why your vent valve is messed up ... I am sure someone will chime in ,Good luck
