Brake pedal makes rear wiper run
Old Sep 18, 2013 | 01:21 PM
greytbig's Avatar
I bought my 2008 HHR LS in April of this year. My rear wiper runs every time I depress the brake pedal. I pulled the relay, as a temporary fix, but that relay also controls opening the rear door, making this a real pain in the a#*! Has anyone seen/had this problem before? I would appreciate any suggestions of where to begin to solve this problem. I have never posted before, but have come here for information many times.
Thank you for your time
Old Sep 18, 2013 | 01:44 PM
to the forum!
A couple things come to mind.
You could have damage to the wiring harness, either through rubbing under the dash or in the firewall area, or you could be suffering an after effect of some prior owner's attempt to install trailer wiring. Does it have a hitch, or prior evidence of a hitch.
The other thought, is did you run a Carfax report on it before your purchase?
Unfortunately vehicles damaged by Hurricane Sandy have flooded the used car market.
Old Sep 18, 2013 | 02:08 PM
greytbig's Avatar
Thanks for the welcome!!
No hitch, no Sandy, BUT it was in an accident involving the rear passenger side. The airbag didn't deploy, so the impact wasn't too intense. Is it possible that some wiring was damaged as a result of this or the subsequent repairs? Do I rule out the relay? Someone suggested replacing that.(no one here) I am not so sure that makes sense, but I really don't know much about it. Don't relays generally work or don't work? Is there anything in between?
Old Sep 18, 2013 | 02:23 PM
Relays can "hang open" or "hang closed" because of an internal failure, you can check the offending relay with a VOM and a 12v power source(off the vehicle), but without my wiring diagrams in front of me....I can't honestly think of any interconnection between the systems.
How long ago was the collision, most auto policies have clauses to remedy "hidden damage" after the repairs, you may want to look into that and have it checked by your dealer or independent technician.
Old Sep 18, 2013 | 03:06 PM
Rear passenger side damage: I would be looking for some damage to the wiring in that area.
Sounds like you have a positive wire for the brake lights and one for the rear wiper that are shorting togeather. Apply voltage to one and both turn on.
I would take the interior trim panels out in the previously damaged area and inspect that wiring completely.
Old Sep 18, 2013 | 04:39 PM
What do you mean by "but that relay also controls opening the rear door", is it an LS or a Panel? One relay, one job, they do not overlap. Very screwed up wiring.
Do the brake lights operate when you depress the brake pedal? I'm thinking that somebody crossed the wires between the 3rd brake light and the wiper.
Old Sep 18, 2013 | 10:39 PM
greytbig's Avatar
It's an LS and I refer to the liftgate release when I said rear door. When I pull the relay for the rear wiper, the liftgate will not release until I put the relay back in. I don't know much about it, but was thinking the same thing "one relay, one job". I got out my diagram of the engine compartment fuse block. I will display it here. #17 is the "Rear Wiper" relay and #18 is the "Liftgate Release" relay. Hmmm, screwed up wiring doesn't sound too far off to me. To view the wiring you speak of, where should I begin to look? By the way, yes, the brake lights operate when I depress the pedal.
Old Sep 19, 2013 | 10:59 AM
IgottaWoody's Avatar
Its also possible to be a ground problem and the ground is just using the other circuit to complete its path....had a car that wouldnt crank over unless the brake was applied..turned out to be..of all things, the cig lighter ground...seeral other circuits were affected also....typical chrysler for you.
Old Sep 19, 2013 | 11:03 AM
Chryslers ued to have a peculiarity that made possible to listen to the radio without the key at all. You could step on the brake pedal and turn on the E flashers and a turn signal, voila the radio would be energized.
halfpanel08
Jan 28, 2015 06:27 AM
arttysHHR
Nov 13, 2010 11:11 PM
andoll83
Apr 1, 2009 07:14 PM
rocko54
7
Mar 8, 2009 12:24 AM
xzombiex66
Mar 28, 2007 05:44 PM
