Vvt solenoid pigtail
Old Dec 1, 2021 | 02:23 AM
Kimberly Brooks Campbell's Avatar
The plastic on both my intake and exhaust pigtails crumbled when I was taking them off to clean the pcv ports in my valve cover. I got them connected just so I could get the car to run but now my baby is having intermittent hard shift issues. Reading here I believe the pigtails could be the problem so I’m going to replace them. I am able to get the exhaust pigtail locally. But no one carries the “intake” pigtail. AND anywhere where I have found it, it’s ridiculously overpriced. The exhaust pigtail is purple and only 23$. The intake pigtail is gray and to order it in I’ve seen anywhere from 50-90$! They don’t even show an intake pigtail at rockauto. Is there a reason I can’t just buy two exhaust pigtails and mark the intake pigtail with like high temp paint on the outside to so it can’t be confused? Is there any difference in the two other than the color?
Old Dec 1, 2021 | 02:37 AM
lazaino's Avatar
Commonly they will have different coding and if you look inside you may see some fins or gaps that will be different on the two connectors. Depending on the difference you may be able to remove a fin to make it work. I've done that to hundreds because the manufacturers don't always sell all the keys to the public and I needed two that were not available so I modified a different one to work. I've use a 1/4" wood chisel to very carefully shave them off.
Can you post a picture of the problem connector?
Ira
Old Dec 1, 2021 | 02:49 AM
Ira
I will check it out and get a pic tomorrow when I replace the bad exhaust pigtail.
I’m not getting any CEL. But as I already know these pigtails are corroded, I have been hyper aware of potential problems so the second I feel a hard shift I’m looking for a place to pull over and reboot.
I did read on another thread that one can go to a junkyard to get retainer clips. So I may just go by my local place and see if I can pick up a salvaged intake pigtail.
Old Dec 1, 2021 | 06:51 AM
Check out RockAuto, under electrical connectors and don’t forget the discount code
axxsys
Jul 30, 2013 09:50 AM
austingrackle
2.4L Performance Tech
11
Oct 21, 2009 11:29 AM
herbalhhrss
Jul 2, 2008 07:47 AM
solman98
Mar 5, 2008 02:52 PM
GER42
14
Jan 29, 2008 07:44 AM
