Warranty
Warranty
would warranty aftermarket, not gm warranty) cover to replace the intake manifold? the quick connect vacuum line broke off and has been backfiring and not driveable at all..brought it to dealership thinking warranty would cover but they said it wont since this piece shouldnt break..
You're asking a blanket question.....so a blanket answer is, "NO".
Probably a hundred different aftermarket companies for "warranty" policies. Each has their own boilerplate. Probably should read your policy for the accurate answer.
Time to search for a good used one, here are the results from a quick search I just did.
http://www.partshotlines.com/parts/c...-manifold.html
Have a hhr that is giving me fits started to overheat turned heater on came out of the red. I changed the thermostat and changed the oil now check engine light is on and AutoZone said was an 02 sensor ordered one and if I could find the blasted thing I would change it out then the fan won't come on tried everything didn't work so put in a toggle switch fan works now car won't start/crank HELLLLLP!!!!!
