Weatherstripping replacement??
Old Sep 26, 2022 | 09:12 PM
Maybe. That's probably a polyurethane in a caulking tube. If that is the seal in question, OP needs to get to a body shop for that information.
We'll just have to wait...
Old Sep 26, 2022 | 10:29 PM
Cyan19's Avatar
Seems like something that is clipped into place, not caulking. (Will provide pictures if needed) Although I am curious if it would work as a replacement. Planning on getting car wrapped so I'm not sure if that would cause problems.
Old Sep 26, 2022 | 10:32 PM
Cyan19's Avatar
Originally Posted by Lonwane
Isn't that the door seal?
I'm referencing the black strip that runs from the door insulation to the back of the hatch separating the roof from the rear quarter panel.
Old Sep 26, 2022 | 10:34 PM
Cyan19's Avatar
Are you referring to the vertical piece that your thumb is touching in the pic? Or the horizontal piece along the roofline, from the rear door to the hatch?
Apologies, im referencing the horizontal piece along the roof. Not what my thumb is touching
Old Sep 26, 2022 | 10:44 PM
Ok, thanks for the clarification. You should take it to a body shop then. They'll know what you need. I really have a strong feeling it comes in a tube. There are no diagrams that show this as a "part".
I'll leave the weatherstripping part numbers up, future readers may be looking for them.
Old Sep 27, 2022 | 07:19 AM
That strip is in fact rubber, not butyl. It’s not in any parts list, it gets replaced with seam sealer.
Old Sep 27, 2022 | 08:18 AM
I still don't know what we are talking about. The side panel to roof joint is held together with "Metal Panel Bonding Adhesive" . The door has a rubber gasket, the windows have a hard rubber gasket.
Old Sep 27, 2022 | 08:58 AM
In this photo the pine needles are pointing to the black rubber strip from the 1/4 panel to the roof panel. Have a close look you’ll see we’re it’s deteriorating
Old Sep 27, 2022 | 09:09 AM
Cyan19's Avatar
Thank you so much, I figured this was the case since I couldn't find any part numbers or diagrams referencing this. Its got a bit of bare metal exposed inside the gap so I've got alot of touching up to do.
Old Sep 27, 2022 | 09:18 AM
If you can tape that rubber back from the roof, mask off the 1/4 panel side and then the roof, scuff the rust bare metal and spray on Eastwood’s rust encapsulator , then prime and paint. You should be good for a couple more years
