Weird theft deterrent issues
Old Dec 30, 2024 | 02:35 PM
  #31
Or just swap the relay for a test
Old Dec 30, 2024 | 02:47 PM
  #32
Jbird's Avatar
Yessir oldblue have tried that already. I’ve literally tried every logical thing except doing the drain test. I’ve been slacking on that and it’s a shame I think that’s going to narrow it down to a circuit that is casting my problems. I am confident it’s a voltage issue. The battery will drain to 12V within minutes of shutting car down. Either there is a short somewhere or something is not shutting down with the key off. I have some errands to run and I’ll be out there with the work lights and my meter testing this evening.
Old Dec 30, 2024 | 03:59 PM
  #33
Okie dokie, let us know what you find
Old Dec 31, 2024 | 04:10 PM
  #34
Jbird's Avatar
Well… I have 150 mA draw with the key out of ignition. Pulled every single fuse and no change. I’m going to hook trickle charge up to it as soon as I cut it off today and see if it’s just a battery voltage issue and if so I’ll just leave her running everywhere I go and hook to the charger at the end of every day. My charger will float the voltage at correct battery voltage without overcharging.
Old Dec 31, 2024 | 04:39 PM
  #35
Gearhead1's Avatar
Did you pull the relays too?
Old Dec 31, 2024 | 04:40 PM
  #36
Pulled fuses but didn’t pull any relays ? Both fuse boxes ?
And fyi. There are some relays on the backside of the BCM. Not accessible unless you pull the BCM.
  #37
Jbird's Avatar
Gearhead1 🤦‍♂️ no
Old Dec 31, 2024 | 04:42 PM
  #38
Jbird's Avatar
My back was giving me fits after pulling all fuses from both fuse boxes. I guess I need to do the relays as well, I’ll get around to it in the next couple days
Old Dec 31, 2024 | 04:46 PM
  #39
Jbird's Avatar
I didn’t pull any of the big maxi fuses either I guess I need to do that. Sorry I know it probably feels like to some that I’m not doing my due diligence but I just had spinal fusion surgery and my pain levels make it hard to think straight especially when I’m up doing something. I will do all that when I recover from last night.
  #40
Gearhead1's Avatar
I cant remember who mentioned relays (BCM believe) but if one those is stuck, that would do it. Could be any of them
