Wet floor....and more
Old Sep 5, 2022 | 12:03 PM
KenK's Avatar
So, after a heavy rain, I got a swimming pool on the pass side floor. After a quick search, found that the likely culprit is the butyl patch under the windshield/cowl trim
But, ironically, now I'm having a blower issue. The blower fan runs, at all speeds, but no air comes out of any vents, no matter which location I have selected. Where would a good area be to begin? I assume pulling the glove box where the blower motor is and checking things out? Thanks!
Oh, and btw, it's a 2006 HHR
Old Sep 5, 2022 | 12:32 PM
Wet cabin air filter, soaked blower motor, first places I suggest you look at.
Old Sep 5, 2022 | 01:34 PM
greg8453's Avatar
Clean out under the cowl and clear the drain(s). Check blower and cabin filter.
Old Sep 5, 2022 | 02:16 PM
KenK's Avatar
Once it stops raining, I'm pulling the cowl, cleaning, and inspecting the square rubber sheet, and will clear the drains if accessible from there.
I didn't even think about the cabin filter, judging by the amount of water I got, I bet it's soaked enough to block airflow. But, again, will have to wait for this crazy rain to stop.
Old Sep 5, 2022 | 02:43 PM
Is the inside of the car being flooded now, or have you put some kind of a cover on it?
Old Sep 5, 2022 | 04:28 PM
KenK's Avatar
I moved it under a big tree, blocking most the rain
Old Sep 5, 2022 | 04:59 PM
KenK's Avatar
Ok, rain let up enough to quickly give things a once over. Cabin filter was soaked and covered in leaves and other debris.
Troubling discovery, and idk how I never noticed it, is the cowel does not sit tight against the windshield. There's a what I would call big gap. I assume this is not kosher?
Old Sep 5, 2022 | 05:11 PM
I is not supposed to be tight just there, the bolts that hold it are pretty far from the windshield. It is cosmetic only.
Old Sep 5, 2022 | 05:16 PM
KenK's Avatar
Phew, ok. Makes me feel better and one less thing to deal with, lol
Old Sep 5, 2022 | 06:39 PM
It’s the cowl opening for the hvac system that’s letting all the water in!
Some links and the part number for the patch and a couple of videos
https://www.google.ca/search?q=hhr+c...&client=safari
