Wet floor....and more
Old Sep 5, 2022 | 07:24 PM
lazaino's Avatar
There is a drain you can clear from under the car that causes the car to flood on the passenger side when it clogs. Way up against the firewall on the passenger side. There's some pictures somewhere that show this.
Old Sep 5, 2022 | 07:25 PM
That if the Ac or defrost was on.
Old Sep 5, 2022 | 07:46 PM
That's the condensate drip.
Old Sep 6, 2022 | 07:33 AM
KenK's Avatar
Found the problem, lol. Wasn't expecting it to be torn so bad
Old Sep 6, 2022 | 07:41 AM
Nasty looking!
A discussion about the patch
https://www.chevyhhr.net/forums/main...l-patch-58597/
Old Sep 6, 2022 | 08:08 AM
It was repaired in the past. Most just cut a piece of sheet metal or plastic and RTV it on.
Old Sep 6, 2022 | 09:10 AM
Lonwane's Avatar
Your photo explains why the cowl wasn't fitting well.
I used aluminun tape to repair mine
Old Sep 6, 2022 | 09:39 AM
KenK's Avatar
Get a sheet of rubber at the hardware store, rtv'd it on. While I was at it, cleaned a handful or two of leaves and debris out the area under the patch. While I was at it, I checked my wiring loom boot, but it was tight and in good shape. Thanks all for the tips and links 🙂
Old Sep 6, 2022 | 10:14 AM
greg8453's Avatar
That was a hack job they did prior. That's why it blew again.
Old Sep 6, 2022 | 12:05 PM
BTW, the patch is needed on 2006 an very early 2007 models ONLY. If you have a later model don't do it.
