When was the Shifter Issue Resolved
Old Dec 4, 2014 | 05:17 AM
taz3's Avatar
What year did GM fix the issue with the shifter? I'm finding conflicting information that it was on the 06 model, but I now read the 07 also had it, so was it sorted out for 08 models?
Old Dec 4, 2014 | 06:09 AM
My 2011 had a shifter issue. What exact issue do you mean? Where did you see it had been resolved?
It is a matter of solenoids getting gummed up or broken.
Old Dec 4, 2014 | 08:04 AM
I've got an '07 2.2 auto and never had an issue with the shifter!
GM did a redesign in '09 to a leather boot from the slider boot and added a storage pocket to the right of the stick for change or maybe sunglasses
Old Dec 4, 2014 | 01:55 PM
taz3's Avatar
I did a google search and read through a few pages here, and there was plenty of discussions from the earlier years that it was an 06 problem, but there was an 07 owner who claimed to have the same issue. Unfortunately there was any update/follow up, after that post. Trouble is, the ones that had issues early, were covered under warranty. Now that most of them are out of warranty, it will be outta pocket, so upgrading to a redesigned unit would be a better choice if there is one.
Old Dec 4, 2014 | 02:07 PM
Depends on which "problem" you have.
The shift solenoid
The brake interlock solenoid
The button rod
I know about all of those from researching on this forum, I am guessing you could find the same repair info I did. It is here.
Old Dec 4, 2014 | 03:32 PM
taz3's Avatar
The shift solenoid
The button rod
I have all of the above, I figured rather then waste time fixing it, I'd just replace the shifter assembly with a revised one, if there was. I did find one local to me in the classifieds here, in working order, so I'll got that route. The other benefit will be once I have one out, and a working one in hand, I'll be able to see if I can improve on the design. this will hlep to repair the shifter in my other HHR, that also has the same issues.
Old Dec 4, 2014 | 05:31 PM
If you have "all of the above", I would be inclined to think it's just dirty and/or mucked up.(i.e. maybe someone spilled a drink around the shifter way back when)
I would 1st try pulling it out, cleaning it and re-lubing.
Old Dec 4, 2014 | 06:36 PM
New shifter will not fix brake interlock solenoid. The ignition recall may fix the key interlock that I forgot to list.
But, OK. Nobody here has been, there done that. (sarcasm again)
In other words; why not just find the problem? There are pictures of the shifter solenoid that probably needs a spritz of WD40. There is a thread about the button and the Dorman repair part number is around somewhere. &etc &etc &etc....
So, to sum up: your brake interlock relay does not work, your key interlock switch does not work, your shifter solenoid does not work and the button rod is broken. Strange string of coincidences.
Old Dec 4, 2014 | 07:48 PM
prod's Avatar
Wow, never had a problem in the last 6 years.
Old Dec 5, 2014 | 02:42 AM
The only shifter problem I've had was a reluctance to come out of Park in cold weather, it was easily rectified by careful cleaning and re-lubrication of the affected shifters.
The triple digit Southern summers had dried up the lube applied by GM on my '06 and '07's.
