Where did my coolant go?
Old May 25, 2011 | 01:11 AM
  #41
Old May 30, 2011 | 04:51 PM
  #42
63falcondriver's Avatar
Originally Posted by 843de
I pop the hood daily because its a pilot thing, once you've had pre-flight checks ingrained in you, you just find yourself doing them on everything. I think a once a week look under the hood is about right for the average driver. As for where the coolant went, maybe it didn't go anywhere. Depending on the engine temp when you checked it in October and the other day, the level in the recovery tank might have been different. If you're not smelling it inside or outside the leak if any is small to insignificant. Also, even though the cooling system is "sealed" to a point, some coolant loss will occur over time, just have to check periodically.
Wow, every day? I open the hood on my vehicles when I change the oil, before I take a trip and if there is a problem. I don't see it falling into the same category as preflighting a plane. (Which I do very carefully). Guess too much is better than not enough.
lil tank
Dec 30, 2013 08:57 PM
Cheko0602
Nov 30, 2013 10:49 AM
donbrew
Nov 25, 2012 09:37 AM
plumb34
Jul 6, 2010 12:53 AM
andyb
Dec 20, 2009 08:39 PM
