Where is the High Pressure AC Switch located on the 2006 HHR 2.2L
Old Oct 4, 2017 | 08:07 PM
rcco's Avatar
I need to replace the AC High-Pressure Sensor on my 06 HHR. I need help in locating it. It seems like it must be well hidden. Any pics would help.
Thanks
Old Oct 4, 2017 | 08:53 PM
Pic is a 2010 SS. But the compressor layout may be the same on a 06.
(silver thing in the red circle what you're looking for ? )
Old Oct 4, 2017 | 09:36 PM
rcco's Avatar
Thumbs up Ac high pressure switch
Thanks for the pic. Quick question though >> It is a little hard to decipher from the pic ... Are you sure this is the high-pressure switch? I believe the low-pressure switch plugs right into the compressor.
Thanks again.
Old Oct 5, 2017 | 06:35 AM
Hmm. Not sure. I haven't worked on automotive AC's professionally in many years. But. That switch is in the AC line block. Not in the actual compressor.
Old school training says by default, the line that goes to the condenser is the high side.
Since the switch pictured, and the line it's attached to go to the condenser (which is the high side ), I would assume it's a high pressure switch.
I just haven't scoped out all the components on my AC system since it's been trouble free since new.
Fwiw. Sorry that picture is hard to decipher. It wasn't originally taken to show the AC switch. It's an old pic from a SS Tmap discussion. Just used it in this thread because it showed the AC pressure switch.
Old Oct 5, 2017 | 07:11 AM
rcco's Avatar
I am very grateful for the pic and info. I think you are correct about it being on the high side line. The way the AC is laid out is a little different looking than some of the generic diagrams I have seen.
This is the part recommended at AutoZone for the 2006 HHR 2.2L for anyone else who may need this info.
Santech A/C Switch MT1247 - Read Reviews on Santech #MT1247
Old Oct 5, 2017 | 08:41 AM
Simply put; it is the only valve looking thing on the hard A/C lines with electrical wires.
Open the hood look at the aluminum tubes associated with the A/C. The bit screwed into one that looks like the part in your hand is it!
Old Oct 5, 2017 | 11:30 AM
Actually it's best seen from under the car... I had to repair the plug wires due to rodent damage on mine a few weeks ago.
Nukundu
Aug 18, 2010 01:16 PM
impulse91
Jul 16, 2009 08:57 PM
sanddragger28
Jul 4, 2009 10:13 AM
MikeX
Sep 8, 2006 08:45 PM
