While driving lost power
Old Mar 11, 2017 | 07:33 PM
Cyndiandred1's Avatar
My son at college was driving on freeway lost all drive power still had electrical couldn't get key out. Had towed HELP he is now stranded. HHR 2010 LT
Old Mar 11, 2017 | 07:55 PM
Hi Cyndiandred1, to the forums!!
Some more information would be helpful. Anything that happened recently, fender benders, potholes, work that was done, etc. Also how many miles, automatic trans or manual, engine size(2.2 or 2.4).
Has the ignition recall been performed yet? If not, that could be the problem. Another issue these trucklets sometimes have, is the underhood fusebox, which has a top and bottom half, begins to separate. This causes the fuses to become not properly seated.
Hi neighbor, is he away at college, or going to Poly or Cuesta?
Old Mar 11, 2017 | 08:01 PM
Have the ignition recalls been done?
take a look at the connection of the large red wire to the under hood fuse box, it could be loose or corroded.
Any Check Engine Light?
Was he using the same key he always has?
Old Mar 12, 2017 | 12:40 AM
We can list literally a hundred possible causes, but that won't likely help you out unless you have tools and a fair bit of hands-on experience repairing vehicles. Otherwise, it's best to have it looked at by a trusted mechanic.
The suggestions above are a good start if you have the tools and background. Add to the current short list the battery needs to be tested, along with the charging system.
Old Mar 12, 2017 | 01:45 AM
she came back at 9:17pm - she left no comments or answers to the questions.
kristen1
Nov 7, 2013 11:30 PM
CHHHR09
Jul 23, 2013 04:09 PM
Bartman101
May 20, 2013 09:03 PM
smoove407
Jun 4, 2010 07:22 AM
NYBLKBEAUTY
Feb 29, 2008 09:57 PM
