Will not start
Old Jun 19, 2025 | 02:30 AM
Ronald Yeakley's Avatar
Will not start
Just replaced both the cam solenoids and sensors
And crank sensors mass airflow sensor and also cleaned the throttle body and put it all back on put it back together and now it acts like it's loading up and doesn't want to start how one do I need to check to even start a relearn process
Old Jun 19, 2025 | 03:20 AM
So far nothing
Will not start after replacing the cam solenoids and sensors and crankshaft sensor also mass airflow sensor and cleaning the throttle body and changing the spark plugs starter and battery tell me what the heck is going on
Old Jun 19, 2025 | 06:15 AM
How about some details like year, model and which engine in your HHR.
And why did you replace all those parts ? Was it running before you replaced them ?
And by “will not start “: do you mean the engine turns over and does not start ? Or it does not turn over at all ?
Old Jun 19, 2025 | 07:38 AM
A lot of parts replaced some need to have a scan tool to relearn them. Battery voltage is important , re check your work, perhaps you missed a connection or ground wire, tighten those 4 bolts in the fuse box
Old Jun 19, 2025 | 08:14 AM
The only one that needs relearn is the crankshaft. None of them would cause a no start. May have mucked the throttle body. May have not connected the battery good enough.
Old Jun 19, 2025 | 11:54 AM
It is a 2010 LT 2.4 l and it also has 315,000 mi on it and that's why I changed All those sensors and then cuz it was everything started going out and I didn't know what else to do I need some help here now check I'm sorry I won't
Old Jun 19, 2025 | 12:04 PM
Check your work, make sure all electrical connectors have been reconnected. If still no change, start reinstalling the old parts one at a time. Some new part may have been bad.
Old Jun 19, 2025 | 12:19 PM
greg8453's Avatar
You need to be able to describe your situation better. Do we know if this even cranks? Where are we at?
Old Jun 19, 2025 | 08:57 PM
Were all of those parts replaced due to a P0016 or P0017? If so the reason it won't start is the timing chain.
What does "it was everything started going out " mean?
Old Jun 20, 2025 | 07:36 AM
PulpFriction's Avatar
What behavior exactly led to you replacing those parts? If did you buy any chance scan for codes?
PSA - When changing plugs , just run a compression test. It adds very little work and time.
