windows down but not up
09 HHR 89k. passenger and rear windows will go down with their individual switches but not up. They work normally from the drivers control. Any suggestions about where to start?
Did you check out the fuses regarding the windows in your fuse box?
You can find that information in the Online Owners manual. CLICK HERE AND CLICK YOUR YEAR
I agree that the master switch is more that likely not supplying the ground to the rear window motor in the neutral position like it should.
Some people have had good luck taking the switch apart and cleaning the contacts.
Here is a thread that will show the inner workings of the switch and it also has a wiring diagram for a 2010. https://www.chevyhhr.net/forums/prob...-switch-46384/
