Wiring and or fuel pump problems need help
Old Nov 27, 2019 | 08:32 PM
I don't know why you insist there should be 2 wires from the fuse box. The entire metal parts of the frame and body are ground. The black wire on the pump goes to the ground point beneath the passenger side brake light.
Why won't you consider that the motor pump is broken? That is a much higher probability than something reached around the gas tank and broke ! of the ten wires running around there.
Old Nov 28, 2019 | 10:24 PM
Leland Brown's Avatar
Thank you donbrew
A mouse got in my car and chewed up all the wires where they branch Off to the connecter for abs trail lights and fuel pump,door latch etc. I fix them with butt connecters and heat shinks
But I think I got bad connection in the in the fuse box for the relay and or I might have wires one or two wrong thank you for your help
Last edited by Leland Brown; Nov 28, 2019 at 10:26 PM. Reason: Spelling and correction
Old Nov 28, 2019 | 10:54 PM
Don't you think you should have mentioned that in the 1st post of this thread ?
Good Luck with trying to splice a bunch of damaged wires. I learned many years ago when I was in the auto repair biz. To fix it right, replace the harness section that's damaged.
peanut9479
2.2L Performance Tech
Apr 15, 2019 07:21 AM
Fievel4
Fuel Economy - Hypermiling
Jan 5, 2015 03:42 PM
ald
Jun 23, 2013 09:36 PM
AZ RADIO
Jan 2, 2007 04:36 PM
mizzouHHR
Nov 14, 2006 05:47 AM
