Replacing wheel bearing - what parts do I need?
Old Dec 15, 2017 | 07:22 PM
hhrumadbruh's Avatar
It's for the front driver side.
2010 lt 4 door.
Looking for whatever is cheapest but not something that is not worth putting in my car if that makes sense.
Old Dec 15, 2017 | 07:42 PM
Hub- GM P/N 22715554
Axle nut - GM P/N 10289657
And you already posted in the How-To, so you have the info you need.
Old Dec 15, 2017 | 09:14 PM
Old Dec 16, 2017 | 03:10 AM
Thank you both.
Is there a certain quality I should be going for? I see some real cheap ones when I search on ebay for that part number.
Old Dec 16, 2017 | 07:31 AM
Hubs from Prime Choice and 1AAuto are good quality same for RockAuto
Old Dec 16, 2017 | 01:45 PM
My theory is: I can replace the chap ones 4 times for the price of the expensive ones. Don't even ask at a dealership, unless you want a heart attack.
At Prime Choice you can pay a few bucks more for a longer warranty.
Old Dec 16, 2017 | 04:01 PM
I’ve sourced from all 3, no problems with quality or shipping time.
I’ve had two sets installed whilst still under warranty from GM they lasted as long as these others.
I got a pair installed now , I purchased from a member from Pittsburgh PA, they’ve been installed now for nearly 4 years.
Old Dec 17, 2017 | 09:00 PM
I might be doing something wrong but I can't get #4 and #5 off. I believe the hub is seized in there good.
I am trying to replace this entire thing - this is basically, if not exactly what I bought at autozone. My research is indicating that I'm not supposed to remove the part with the 3 bolts?
The flat smooth gray piece on top with the black ABS clip wire is the part on the old piece that won't come out. Am I supposed to remove all that or not?
Old Dec 18, 2017 | 07:52 AM
You need to remove the 3 bolts, 15 mm and the axle nut, 30 mm for non Turbo .
Cascious King
Aug 30, 2016 07:10 PM
07WhiteHHR2LT
May 9, 2016 09:11 AM
hurst2001
100
Nov 11, 2012 06:49 AM
8t7vette
Aug 2, 2010 02:09 PM
