2.0 Timing Chain Problem at 61,000 Miles?
Old 11-14-2017, 10:58 PM
  #41
If the dot on the balance shaft sprocket is at 0600 then that white spot on the timing sprocket is the mark. Judging by the oil drip it is not at 0600.
Old 11-15-2017, 09:23 AM
  #42
That spot is on the spacer washer, the crank sprocket will have a dot in it at 5:00 o’clock the keyway will be at 12:00 o’clock
Mine if I recall was at 12:00 o’clock for #1 Piston TDC
Old 11-15-2017, 11:45 AM
  #43
Now this is strange; more than one illustration in Mitchell OnDemand 5 has the keyway at 1200 when installing the chain. The mark on the balance sprocket is at 0600 with the keyway at 1200.
Old 11-15-2017, 02:20 PM
  #44
Right !
Balance shaft sprocket mark at 6:00
Timing chain sprocket mark at 5:00
Crankshaft keyway at 12:00
Old 11-15-2017, 02:38 PM
  #45
rlee63a4's Avatar
OK. There was a thin washer covering up the crank sprocket. With the cam sprockets timing marks still lined up, I found the red link clearly half a link off the white dot.
rlee63a4 is offline
Old 11-15-2017, 03:50 PM
  #46
So you’re lined up ready to, swap out that chain!
Old 11-15-2017, 04:11 PM
  #47
rlee63a4's Avatar
Yes, indeed. After finally getting to this point, I'm just glad I didn't find the red link lined up with the white dot. I'll start taking it all apart, place the order, and be cleaning and prepping all the miscellaneous stuff I had to remove while waiting for the box of parts to arrive.
rlee63a4 is offline
Old 11-15-2017, 07:46 PM
  #48
Yep, relief to know you really have found the problem.
RJ_RS_SS_350 is offline
Old 11-16-2017, 03:39 PM
  #49
rlee63a4's Avatar
I didn't plan on being back so soon, but I just wanted to let you all know I found the root cause of the problem--the top bolt hole of the timing chain guide has a big crack. I imagine this could have been a disaster had I continued to drive the car for any length of time after the check engine light came on and that end of the guide had broken off completely. Who knows what the chain would have done. Whew...
BTW, I haven't looked for that missing chunk of guide, but it's probably all ground up by now anyway.
rlee63a4 is offline
Old 11-16-2017, 06:18 PM
  #50
Mine was cracked also at 62,000 miles and the second one was intact at 150,000.
Quick Reply: 2.0 Timing Chain Problem at 61,000 Miles?
