XM Installation Location
Old Jan 2, 2008 | 06:00 AM
andoll83's Avatar
Where in my 2006 HHR should I mount my Roady XT? Is it hard to run wires? Anyone have any pics of their install of any aftermarket XM radio?
Old Jan 2, 2008 | 10:57 AM
Chizzer's Avatar
Mine was factory installed, and they mounted the receiver on the center of the roof just near the back end.
Old Jan 2, 2008 | 02:40 PM
andoll83's Avatar
I mean where should I mount the radio itself.... right on the dash by the hazard light switch? Or is there a more preferable location? Any Pics?
Thanks!
Old Jan 2, 2008 | 04:04 PM
HHR_ROX_CALI's Avatar
andoll83-
I mounted my Roady receiver on the center console between the seats just in back of the little rectangular cubby and just in front of the rear cup holder. It's powered by the rear power point. It's not the killer set-up but it's clean, out of the way and works fine. I'll post some pix next chance I get in a couple of days so you can at least check it out and consider it.
Old Jan 6, 2008 | 09:56 AM
Here's the set-up...
Like I said above, not the perfect set-up, just an option to mount it out of your way and not on the dash. Plus- it cost me nothing!
Old Jan 6, 2008 | 11:03 AM
andoll83's Avatar
How are you supposed to see it when you drive
Old Jan 6, 2008 | 11:08 AM
enri9267's Avatar
Try this site for mounting solutions.
http://www.ram-mount.com/
Old Jan 6, 2008 | 11:36 AM
candid228's Avatar
Here are some pics for another option. I installed mine by using existing holes and compartments. The only mod is to the mat in the place holder under the switches. I have all the wiring behind the xm except the audio to the radio.
Old Jan 6, 2008 | 01:06 PM
That's one of the cons- and pros. You can't see it very well. But I use the remote to change it and don't really need to see the face. And it's out of my way in the front. Again- not the ideal set-up.
As far as candid228's set-up- that looks great. Of course, that looks like a panel dash- that would block the window buttons for most of us. And not a Roady.
Ideally, I would just buy the aftermarket receiver for the XM-ready HU but that's a few hundred $$$ installed- this was free.
Old Jan 6, 2008 | 09:55 PM
Smoke Wagon's Avatar
might not be much help to you, but I mounted a Sirius Sportster4 in another car by removing a trim panel, and fabricating a bracket that had 2 L bends in it. 1 L bend to mount it to my climate control unit...slid the trim piece back on, and the opposite L bend was where I mounted the Sirius receiver, so it sits just to the right of the console, but is solid enough, and out of the way:
Perhaps something similar could be done in the HHR, although the trim sure seems to fit tighter, and doesnt give as much as other cars.
Lee3333
"How To" Tutorial Library
7
May 20, 2019 10:27 PM
JoeCanadian69
2.2L Performance Tech
12
May 24, 2007 09:16 PM
thehizzle06
May 19, 2007 11:34 AM
JOEK86
Oct 14, 2006 06:52 PM
Lee3333
Apr 23, 2006 03:25 PM
