XM Hardwire (Pics)
Old Mar 26, 2008 | 04:37 PM
andoll83's Avatar
XM Hardwire (Pics)
I hardwired my XM to the fuse panel by the passenger seat, mainly to turn off the xm when I open my door, a neater look, and to free up the lighter socket for chargers, gps, etc.
It looks a little shoddy, but it works!
I took the cap off of the lighter plug, and removed the little spring loaded nub and fuse, wrapped wire around the inner contact, as well as one of the side ground springs, and wrapped 'er all up with some electrical tape.
I bought an Add-a-Circuit.... WELL worth the $6, and plugged it into the #21 Fuse location (with a 5A mini-fuse to match the one I removed from the cigarette plug)
I grounded it with a simple alligator clip on the bracket used to hold the cover for the fuse block.
And here is where I mounted it.... ran the wires through the vent:
Old Mar 26, 2008 | 04:48 PM
karen1953's Avatar
I don't any pics. just X
xzombiex66's Avatar
there are no pics:redXdance
Old Mar 26, 2008 | 04:51 PM
shaginwgn's Avatar
he put them on his geocities site but the pics were too big of files for the site and geocities resricted the site untill he upgrades it
Old Mar 26, 2008 | 04:52 PM
andoll83's Avatar
fixed 'em
Old Mar 26, 2008 | 05:06 PM
karen1953's Avatar
Oh good now I see them,,,Thanks!
Old Mar 26, 2008 | 06:37 PM
outlandishhhr's Avatar
XM Hardwire (Pics)
Nice job. I have mine in the same location, but still using the cig socket, how do you have it hooked up the the aux imput? (couldn't see in the pics) Looks like i will be using your idea. Where did you get the add a fuse thing?
Old Mar 26, 2008 | 09:25 PM
andoll83's Avatar
I just fed it down and through the side of the dash next to the radio.... added an aux splitter in case i want to add an mp3 or anything
I got the Add-a-Circuit at Advanced Auto Parts for about $6.50
Old Mar 26, 2008 | 09:59 PM
hhrcrafty's Avatar
Very similar to how I did mine, except I spent another $4 and purchased another lighter socket and wired that to the add-a-fuse instead of hacking up the XM adapter. I also used a ring terminal to ground to one of the bolts supporting the BCM/fuse panel. It all tucks perfectly hidden behind the fuse panel cover.
Here is a pic of the unit installed in the upper dash compartment. No new holes were drilled in the compartment:
ecl
Mar 20, 2010 02:31 PM
1SICHHR
Dec 29, 2007 11:20 PM
Kingfrog
Aug 26, 2007 11:03 AM
Chizzer
Jun 29, 2007 08:18 PM
dnbguy86
Feb 7, 2007 11:47 PM
