How long does it take to install a PAL?
Old Apr 13, 2008 | 09:26 PM
aah111's Avatar
Hi, I just bought my HHR and ordered a PAL ipod link for it. The dealer called and said it had arrived but, since they've never installed one before, they don't know how complicated the install is and how long it will take. Does anyone know? I would like to know if I can just wait an hour or so at the dealer or if I need to arrange alternate transportation while they have my HHR.
Thanks in advance
-Alan
Old Apr 13, 2008 | 09:29 PM
ChevyMgr's Avatar
Average time should be around 45 minutes.
Old Apr 13, 2008 | 09:37 PM
imagepower's Avatar
Hi,
How hard is it to install yourself. I do a lot of my own auto work.
Thanks,
Mike
Old Apr 13, 2008 | 11:42 PM
suburbanjunior's Avatar
It is not hard. It is mostly just adding wires that just plug into factory harnesses. I did not have the XM option so it was easier. The most diffucult part is taking the radio out and just putting everything back together. Good Luck, John
Old Apr 14, 2008 | 07:20 AM
Don't know about anyone else, but if it's their first install, you might want to arrange that alternate transportation.
Old Apr 14, 2008 | 08:21 PM
aah111's Avatar
Yeah, that's the only thing. Since it's their first time, they might take a bit longer than average.
Old Apr 14, 2008 | 08:23 PM
ChevyMgr's Avatar
Agreed
Old Apr 14, 2008 | 08:38 PM
TomsHHR's Avatar
I saw something about unpluging the air bag fuse and the battery, I may be wrong, but check into it.
Old Apr 14, 2008 | 08:41 PM
tim_tenn's Avatar
Here's the link to the "How To..." for getting to the radio so you can plug in to it. Very good description and photos.
http://www.socalhhr.citymax.com/hhrradioremoval.html
Old Apr 14, 2008 | 08:43 PM
tim_tenn's Avatar
My PAL has been ordered and I plan on installing it myself. The link I posted clearly shows you how to get to the radio so you can connect. I have already run cables into my upper glovebox (for my Sirius radio and power for my Garmin Navigator), so running the PAL cable up there will be no problem. The hole is already open.
