Pac Audio adapter for adding amplifier
Old May 22, 2008 | 12:26 PM
Dremin2flyhi's Avatar
has anyone tried to use the pac audio adapter for adding the rca outs for the use with a sep amp setup-- i found the number to be AOEM-GM1416A.. think this is a better way of doing it--without having to cut into the wiring and cabling --maybe risking of shorting out the head unit... any feedback would be nice... thanks in advance
Old May 24, 2008 | 09:36 PM
hhrcrafty's Avatar
Do you have the premium or non-premium setup? If non-premium, I think we can use the Metra 71-2104 replacement harness to tap into the factory low-level inputs and install RCA plugs on them. I am probably going to pull my stereo on Monday to confirm this, but if it works it'll be less expensive than the PAC adapter.
Old May 25, 2008 | 08:40 AM
i have the prem system with the facotry sub... and was wondering where this unit plugged in--- at the head unit or on the sub box at the amplifier. ? gonna add a small 10 with an "old school" punch 45 --that is still around and kicking good....
Old Jun 13, 2008 | 06:06 PM
spudnugget's Avatar
are you sure that is the right adapter? I used that on my base system and it works great except I found it easy to fit in the dash with some plastic cutting.
Old Jun 14, 2008 | 02:17 PM
according to their application guide on their website....
Chevrolet HHR 2006-2008 AOEM-GM1416A
http://www.pac-audio.com/oem1kits/listallaoem.asp
i have gotten it in --but havent started the install yet.... gotta cut some acrylic parts for the box when i can get access to my waterjet machine at work.. I will post and give an update---but it maybe a few weeks....
cfriske
Mar 5, 2011 01:38 AM
cfriske
Jun 2, 2010 11:34 PM
BigJHHR07
Oct 2, 2008 09:05 PM
CrashMan82
Aug 9, 2007 05:13 PM
