Want to get rid of chimes
Old Oct 5, 2008 | 07:34 PM
Chris-HHR's Avatar
I just finished updating my system with new speakers, amp, sub. Now the chimes etc are vey loud. I understand these go through the front left. I was just sending the front low level signals to the amp. If I want to lose the chimes can I just use the rear signals? Also, I've heard about hooking up a speaker to the front to keep the chimes but will this work with a low level signal straight to a speaker?
Just wondering how I should wire everything? I've got the wiring diagrams but I'm not sure what I need to do.
Old Oct 5, 2008 | 07:57 PM
Rcflyboy's Avatar
You must be using the factory head unit? Sorry to say I don't know how to fix your prob. (below is the only way I know to fix it)
Myself, I replaced my head unit and had to install a Metra GMOS-LAN-03 for the GM Onstar and chimes to work. It controls the volume coming from the chimes in the left door speaker.
I recently added an amp. so I lost my chimes because I ran new speaker wires. I plan to add a very small speaker to the Lan left speaker wire to get the chimes back. Just haven't got around to it yet.
Old Oct 5, 2008 | 09:11 PM
Chris-HHR's Avatar
Yes, I'm still using the factory HU. I'll upgrade eventually, but the factory HU is good for now.
sbrown1400
May 3, 2015 02:26 PM
Blue Beast (aka Boydie)
Apr 1, 2015 12:22 AM
HWD510
Apr 17, 2013 11:00 PM
vneal2004
Sep 21, 2012 09:31 AM
08redhhrss
Oct 6, 2008 06:10 PM
