speed signal,reverse signal
Old May 11, 2009 | 09:08 PM
ummlee's Avatar
hi gang I am installing a pioneer avic f90bt in my 2007 hhr I bought it with the 6 speaker no xm no onstar, I am trying to find the output wires for the VSS speed sensor wire and the reverse, I am using a metra harness for power etc. anyone know the location and colors of the speed signal input and reverse gear input.
thanks
Old May 12, 2009 | 01:22 PM
Sno White's Avatar
Don't know why you would want reverse, but the stock radio uses the Low Speed CAN for speed info. Reverse I suppose could always be taken off of the backup light.
Metra or one of the other radio interface developers have circuits to do the CAN interface.
Old May 12, 2009 | 01:54 PM
ChevyMgr's Avatar
Backup camera maybe?
Old May 12, 2009 | 08:23 PM
ummlee's Avatar
yes for backup camera, so the HHR has no VSS wire unless you use the can interface box
thanks
Old May 13, 2009 | 01:08 PM
Sno White's Avatar
Yes, the HHR does have a VSS for a Manual Trans and an OSS for Auto Trans. ChevyMgr would be best to say where the wires would be best accessed, but would have to know AT or Manual trans.
Old May 13, 2009 | 02:24 PM
ummlee's Avatar
its auto tranny, will the oss wire work the same as the VSS?
Old May 13, 2009 | 09:30 PM
Sno White's Avatar
Well the 2009 FSM seems to call it the VSS and the OSS(Output Shaft Sensor) interchangeably for the Auto Transmission, 2009 RPO code MN5 or 4T45-E. All I can tell you is the sensor is somewhere on the Transmission(I can't tell where from the pictures in the FSM, nor looking at my own vehicle. Though I suspect it is under the fuse box area. The two wires go to the Transmission Control Module(TCM) to pins 16 & 41. The TCM is one of the two boxes located in front of the engine compartment fuse box underneath the plastic cover. The wires are colored Yellow and Purple, are twisted together as a pair and there is no splice or connector between the VSS/OSS and the TCM.
I have no idea what type of signal the VSS/OSS puts out or what your radio/navigation unit needs, the installation manual does not say. In fact your installation manual does not specifically reference the “VSS” as such.
Oh, the Yellow wire is referenced as “OSS High Signal” and the Purple wire is referenced as “OSS Low Signal”.
That's all I don't know.
Good Luck!
Old May 14, 2009 | 01:15 PM
Sno White's Avatar
I think I just found your VSS/OSS sensor. I was rotating my tires for the first time and was looking around at things I had not seen before.
Take off the front passenger tire and to the rear of the drive shaft you will find a two-wire connector on the aluminum transmission case. It even looks like the pictures in the FSM.
Old May 15, 2009 | 07:33 AM
ummlee's Avatar
thanks I am going to do some more research and see what exactly the radio needs,
MaryJane
Feb 14, 2012 06:13 PM
otacon
Jul 5, 2011 10:01 AM
stephenm
Dec 2, 2010 04:35 PM
RkyMtnHHR
Nov 20, 2009 08:15 PM
1Panel2NV
15
Jun 19, 2008 03:15 PM
