Dead Radio/Door Chime
Old Jun 22, 2009 | 04:03 PM
JG27AD's Avatar
Hello, all !!
I had to have my 2007 aligned and replaced the front tires. When I picked up the car at the end of the work day the radio was completely dead... no clock, no nothing. Also, the key-in-the-ignition-door-ajar or seatbelt-not-buckled chime does not sound.
The shop says that they do not disconnect the battery when they do undercar work.
I looked at the fuses and they all look intact.
Any advice?
Thanks
Jim
Old Jun 23, 2009 | 04:41 PM
FlaHHROwner's Avatar
did you check both fuse boxes? one is under the hood, the other is on the right side of the console by the passenger seat footwell area
Old Jun 23, 2009 | 05:09 PM
Sno White's Avatar
Originally Posted by JG27AD
Hello, all !!
Any advice?
Thanks
Jim
If you have the upgraded radio with the separate Amplifier, there is also that fuse in the inside fuse box.
Old Jun 25, 2009 | 08:32 AM
JG27AD's Avatar
Yes, I have checked both fuse boxes. As far as I can tell all of the fuses are intact. Is there any "connection" between the radio and the chime? They seem to be the only things that have failed. Also... I can't say that I ever noticed if the turn signals emit a tic-toc sound when activated. My HHR does not. Is that another failed system?
Thanks.
AD
Old Jun 25, 2009 | 08:37 AM
txbass06's Avatar
Thanks.
AD
Mine make that sound. I think I remember reading a thread where someone put an aftermarket head unit in their car and had the same problem as you. No seat belt alarm or turn signal click
Old Jun 25, 2009 | 11:49 AM
Sno White's Avatar
The radio is required for any of the "Chimes" to work. The radio delivers them to the left front speaker. So the fact that the chimes are not working is no surprise since the radio is not working! That is the logical connection you are looking for.
You have a "Radio" problem and I would say it was unrelated to the recent service. There are certainly many wires feeding the radio, but what is wrong? Could be a bad radio.
Old Jul 30, 2009 | 01:59 AM
JG27AD's Avatar
Thanks for the help!! The dealer replaced the faulty radio and all is good !!!
AD
FSU_Noles
May 23, 2023 01:32 PM
kornellred
Jul 14, 2021 06:59 PM
chitownmike
Sep 18, 2013 10:05 AM
stowell1976
May 7, 2012 03:37 AM
Blue Lightning
Jun 15, 2011 10:57 AM
