Kappa One - Install Help Needed
Old Sep 16, 2009 | 11:01 PM
Spawn21's Avatar
I just purchased an Infinity Kappa One amp. I am so confused about hooking subwoofers up and what I should be looking for.
The amp is a mono block amp. Which means there is only one channel, but there are 2 positives and 2 negatives. They are internally wired in parallel. The amp is rated at 500 watts RMS at 4ohms and 800 watts RMS at 2ohms.
What are my subwoofer wiring opinions?
Old Sep 16, 2009 | 11:05 PM
Father Azmodius's Avatar
Your wiring options depend on what sub/subs you plan on using. What are your plans as far as how many subs, and whether they'll be single or dual voice coils?
Old Sep 16, 2009 | 11:14 PM
Spawn21's Avatar
Well, I have 2 Pioneer Premiers. 4ohm DVC rated at 1000 watts RMS. I know I can't run both due to the underpowering factor.
I was thinking, if it was possible to run one of these speaker at a 2ohm load, it should be fine. I don't think underpowering a subwoofer by 200 watts would cause too much harm.
If that wasn't possible, I was going to go shopping for a new subwoofer setup to match the Kappa One. I tried to call the support hotline for Infinity, but couldn't understand what they were saying.
Old Sep 16, 2009 | 11:20 PM
Spawn21's Avatar
Here is what I got:
Kappa One - Specs
Pioneer Premiers - Specs
Old Sep 17, 2009 | 06:52 PM
Spawn21's Avatar
Any help at all??
If somebody could find diagrams for different subwoofer setups for "internally wired in parallel" mono amps would be great. Please post a link.
Old Sep 17, 2009 | 07:31 PM
Rcflyboy's Avatar
Go to wwwCrutchfield.com there is a how to section on different ways to wire amps. All the info you should need is there.
Old Sep 18, 2009 | 03:15 AM
Spawn21's Avatar
Thanks for the help. After digging around and what not, I found my answers.
I'll be honest, I expected more from a Kappa Series amp. I'm not too impressed. I'll buy better subwoofers though and see if there is any difference.
Old Sep 19, 2009 | 03:05 AM
jerseymike68's Avatar
Great coordination
jgoldwood
Apr 20, 2010 08:43 PM
goatcheez
Jul 26, 2009 08:24 PM
220
7
Apr 11, 2009 09:42 AM
Sunrise HHR
Aug 14, 2008 12:55 PM
BlackHHR06
Jan 30, 2008 09:30 PM
