What are my chances on blowing my sub?
Old Jan 2, 2010 | 09:25 PM
hatetoorun's Avatar
I am intalling a Kicker CVT 8". I currently have a Kenwood amp sitting in the closet that has a 300w RMS and a max 1000w. I am scared to install this amp. What are your thoughts?
Old Jan 2, 2010 | 11:03 PM
IgottaWoody's Avatar
If the speaker is rated higher then the amp then no problem.....other way around ,and one day you or somebody forgets and cranks it and pow.......you get the sweet aroma of fried voice coil!!
Old Jan 2, 2010 | 11:28 PM
hatetoorun's Avatar
Thats the thing..... the kicker cvt 8 is rated I think 200rms and 5-600max.
Some one on this board has this same amp and sub. It just seems dangerous to me, even with the amp tuned down. Hell, I might have to dish out more money to buy a new amp.
Old Jan 3, 2010 | 01:07 AM
CavittyCreep's Avatar
depends on how you wire and it depends on your enclosure
is it the 8104D amp? wire the coils in series, turn gain down, and you should get a useable response but not the best sound...bridge it in parallel and call the fire dept
class d gets hot so keep it in an open space
you get what you (will or won't) pay for ... spend a few bucks and get a good amp
Old Jan 3, 2010 | 05:59 AM
bigw10921's Avatar
I've seen more speakers blow from trying to produce crap from an underpowered amp...Trying to get a speaker to produce the sound of a distorted amp clipping at high levels can blow the speaker easily....I usually run speakers that are under rated for the amo i am using and leave the amp mid way up
Old Jan 3, 2010 | 09:04 AM
hatetoorun's Avatar
Alright, a new amp it is. How is the Alpine MRP-M500? It seems to have the perfect power specs.
WarrenG
Jul 9, 2022 06:31 AM
bigjacksauto
2.0L Performance Tech
28
Jul 6, 2013 05:26 AM
bigjacksauto
56
Nov 6, 2012 02:01 PM
MWG2
Jan 15, 2008 08:39 PM
courthousedeb
Jul 10, 2006 01:13 PM
