PAL Personal Audio Link
Old Jan 28, 2010 | 07:12 PM
isaacm66's Avatar
Hello everybody, I know this topic has come up a bunch of time, but i have a few questions.
1. I have a 2007 HHR LT (no satelite radio), is the only thing i need part #19201522 from http://www.gmpartsdirect.com/results...mber=19201522?
2. How hard is it to install, does it require any cutting of wires and crimping?
3. Does anyone have a pdf of the install instructions?
4. For everyone who has it do you recommend it?
Old Jan 28, 2010 | 07:53 PM
3amigos's Avatar
If you do not have satellite radio, go to Best Buy and purchase an aftermarket iPod controller. I made the huge mistake of purchasing the PAL from my GM dealer. The dealer I purchased it from refused to return it, so I went to a second dealer after having a myriad of issues. They replaced the PAL with a new one, but I continue to have problems; such as the volume is much lower playing through the PAL, there is a lot of digital noise in the background, it was difficult to install (you have to cut and solder a wire from the main junction block), and I do not know if I can get this one replaced. I wish I never would have purchased it - especially knowing what I know now. Right before I bought this for my car - a friend of mine purchased the aftermarket item from Best Buy. It was easy to install, no wires to cut, etc. The main reason I bought PAL was it was a GM licensed product that would work with the iPod and XM.
Old Jan 28, 2010 | 08:12 PM
isaacm66's Avatar
thanks for the info.. do you know the name of the item you are mentioning from Best Buy?
I found the " Neo Gateway for GM " from http://www.icarkits.com/ and i also found Neo Pro link from http://www.neocaraudio.com/index.php but i can't find anybody reviewing this items.
Old Feb 3, 2010 | 08:47 PM
3amigos's Avatar
I think it was by Periphial(?), I had my PAL on order when a friend I worked with bought a new Impala - that did not have sat radio. He bought that. It was A - a ton cheaper, B - easy as heck to install, and C - not the P I T A, that the PAL has been.
Starbukfan
Jan 27, 2011 08:31 PM
JTCorbin
May 9, 2010 08:45 PM
jmstro04
Jun 27, 2008 03:39 PM
