Need ideas
Old Dec 15, 2011 | 06:06 PM
dr_fosg8's Avatar
Need ideas
Ok, so far I have repalced the struts, control arms with new bushings and ball joints, new end links, and today new sway bar bushings. I am still getting a clunking sound, but only when driving slow and not consistently. Anybody have any ideas of where to look next? I have an appointment for it to go in next Tuesday, really tired of changing parts.
Old Dec 15, 2011 | 07:51 PM
Strut bearing?
https://www.chevyhhr.net/forums/brakes-%7C-suspension-%7C-shocks-%7C-struts-24/front-end-clunking-solved-36091/
Old Dec 16, 2011 | 06:28 AM
dr_fosg8's Avatar
Is it possible I got bad Mounts? Those are new also.
Old Dec 16, 2011 | 07:52 AM
Not necessarily, a lot of guys don't get new ones when they get struts and I was guessing you didn't. You are saying you have new top strut bearings, right?
Old Dec 16, 2011 | 08:33 AM
dr_fosg8's Avatar
If the bearings come inside the new top mounts then yes they are new. I was talking to a guy at work that suggested it might be a worn axle. Any thoughts on that? That makes sense since I only get the noise at low speed when turning over bumps such as entering and leaving driveways
Old Jan 1, 2012 | 06:34 PM
06hhrls's Avatar
the problem could be the intermediate shaft. it is a common problem on these. it sounds to me like the same noise i currently have and that is what mine is. only problem is that even after replaced they tend to go out again.
Old Jan 1, 2012 | 08:19 PM
dr_fosg8's Avatar
I have found the problem to be with the springs that came installed on the Monroe quick struts. The the top two coils of the spring were rubbing/binding together creating the noise.
Bluestreek92
7
Jul 19, 2012 10:43 AM
LTSport08
Dec 24, 2008 11:05 AM
EvGottie
Aug 3, 2008 07:19 PM
longhorn
Aug 30, 2007 09:00 PM
HOT PANEL 2007
South Mountain
7
Aug 6, 2007 08:15 AM
