gold line alignment kit
Old Dec 23, 2011 | 10:00 AM
88hhr's Avatar
hi ,I was woundering if anyone used the alignment kit with the gold line lowering springs? or if you went without, is it something i need or not .
Thanks
Old Dec 23, 2011 | 11:44 AM
tmerkle111's Avatar
I got it when I bought the gold lines. I would get it, because you will most likely be out of alignment and that is what you will need to get it back. I would get it, because I'm sure the tire shop will charge you a lot more.
Old Dec 24, 2011 | 12:22 AM
Here is the 'camber kit'...Probably better to have it & not need it, as opposed to visa/versa.
Old Dec 24, 2011 | 05:46 PM
tracy waddell's Avatar
I must be one of the lucky one's. Lowered mine with Gold Line springs and no alignment needed. Everything lined up the way it should be.
Old Dec 29, 2011 | 05:01 PM
Yonash's Avatar
i ordered one when i got my GoldLines, and after my buddy and i installed my springs, i took it to my tire shop for an alignment check, and it didn't need them. but several months down the road, got new tires, springs had settled, and i was out of alignment, and was glad i had bought the kit, because i got it aligned real quick-like, because they didn't have my camber bolts in stock that day.
jonny4eyes
Oct 22, 2011 04:54 PM
pcidiot
Apr 27, 2011 12:28 PM
dblackwood
Apr 4, 2009 02:45 AM
VictorySpark08
Feb 17, 2009 05:03 PM
ramz28
2.4L Performance Tech
Apr 4, 2006 01:45 PM
