GPS Install Speed Pulse Location
Old Aug 12, 2006 | 06:40 AM
fredp's Avatar
Does anyone know where I can pick up the speed detection circuit speed pulse signal? I'm guessing it is probably available at the BCM, but I have no idea which wire it is.
Thanks very much!
Old Aug 12, 2006 | 07:43 AM
TomsHHR's Avatar
The GPS shows the MPH, unless you are tring to show the difference. Mine is really accurate.
Old Aug 12, 2006 | 08:22 AM
fredp's Avatar
Thanks. I'm pulling out the premium sound system and installing a Pioneer AVIC-Z1. It uses the signal to maintain accuracy when the GPS signal is not present, so I need to get to the signal to connect to the receiver....
Old Aug 15, 2006 | 02:20 PM
monster5601's Avatar
I looked this up for HVROD but never heard if it worked or not. Here is what I sent him....
If you have an automatic, then the ECM C3 (Gray) connector:
Pin 66
YELLOW
Vehicle Speed Sensor Signal High (w/M86)
Pin 67
PURPLE
Vehicle Speed Sensor Low (w/M86)
Old Dec 9, 2006 | 03:03 PM
chadfosmire's Avatar
Where are those located??
Jpbaker
Jul 4, 2015 01:57 PM
Aggie92
Maintenance and Upkeep
Nov 13, 2014 11:37 PM
oney
2.0L Performance Tech
Mar 16, 2010 09:23 PM
08blackHHRSS
Mar 3, 2009 11:27 AM
