Koni struts and rear shocks
Old May 23, 2012 | 05:00 PM
capp002's Avatar
i got the koni struts and koni rear shocks all installed all i can say is very nice,with the lowering springs and ttr rear sway bar my car handles ten times better than i thought it would. thank you aaron (turbotech)
Old May 23, 2012 | 05:10 PM
Luv my Koni's!
Glad to hear you're a happy camper capp.
Old May 23, 2012 | 05:22 PM
capp002's Avatar
thanks 843 there sweet!!!!!!!!!!!!
Old Aug 24, 2012 | 09:04 AM
BOON's Avatar
Im new to the forum, and the hhr.
Im interested in the koni struts and rear shocks, suggestions on settings.
I just recieved my GoldLine springs and would like to replace the struts while I have it apart.
While Im under the car I will be replacing the sway bar bushings, end links, and looking for anything that might need attention.
Will also be adding the ttr rear sway bar.
Any suggestions on things I should check.
Old Aug 24, 2012 | 10:46 AM
TurboTechRacing's Avatar
Former Sponsor
We carry the Koni's
Get a Turbo Tech Racing Upper Engine mount also.
Old Sep 6, 2012 | 08:54 AM
skyline26's Avatar
KYB vs KONI ??? pros/cons..anybody try both?
Old Sep 6, 2012 | 09:34 AM
kwe45919's Avatar
Koni will be the better choice pending your needs.
The KYB's are a tad bit better than factory FE1 or FE3 shocks/struts but not quite as good as the FE5's so I've been led to believe.
Old Sep 6, 2012 | 03:19 PM
Former Sponsor
Agreed, Koni is best, but KYB Excel G's are equivalant to the FE5 struts.
Old Sep 6, 2012 | 08:51 PM
skyline26's Avatar
im looking for fe5 equivalent to accommodate the pedder springs
Old Sep 6, 2012 | 08:59 PM
kwe45919's Avatar
I guess I should have stated the the KYB GR2's are FE1,FE3 replacements.
The Excell's are definatly FE5 replacements.
