Question about the ZZP rear sway bar.....
Old Aug 5, 2012 | 11:46 AM
Nazgul 9
Guest
Posts: n/a
Question Question about the ZZP rear sway bar.....
So I was wondering if anyone has the ZZP Progress Rear Sway Bar
Item #: PRG-62.0430... and if so can you tell me how you like it??
Thanks!!!
Old Aug 5, 2012 | 03:58 PM
prod's Avatar
I have one. You can get them at local shops too. Its a good improvement on the road to reduce body roll. It tucks up into the rear beam so ground clearance isnt reduced.
If you are into driving fast, track or auto-x, you might want a stiffer bar, like powell hardcore or xxx.
Others on here like the TTR, but I havent tried it.
Old Aug 5, 2012 | 04:07 PM
Nazgul 9
Guest
Posts: n/a
Thank you for the info Prod :)
Old Aug 5, 2012 | 05:40 PM
prince_bigd's Avatar
Yeah I've been researching nazgul and the progress is a 22mm or 3/4 inch rear where as the TTR is a 25 mm or 1 inch rear. The TTR is offered from turbo tech racing in our vendor section and it's priced better than even the cheaper ones on Ebay or Amazon. the xxx and Powell I believe are 1.25 or larger and may be a bit too large for street driving because this could cause snap oversteer unless you tune or swap your front bar also
Old Aug 5, 2012 | 06:13 PM
Nazgul 9
Guest
Posts: n/a
Thanks for the info Prince... that was about what I came up with also...
Old Aug 6, 2012 | 08:12 PM
alexrckid's Avatar
running, on the street, a TTR on my 2006 HHR LT.........think it's mighty fine.........highly suggested.
Old Aug 6, 2012 | 10:14 PM
moonsign's Avatar
I be running a Powell "Hardcore" 1 1/4" bar for a couple years now, and it does'nt do anything funny, even in the rain, on slick streets. The "Hardcore" bar would be about tops for the street and some track time, as the XXX bar borders on being just a little stiff, and in the rain could make the tail end a little happy. I'm more than pleased with the handing, and do a little autocross, and it works super dupper. Slot car cornering. "Moon"
Old Aug 6, 2012 | 10:51 PM
Nazgul 9
Guest
Posts: n/a
Thanks for the info guys :) I think for my money and my driving style I am going with the TTR rear sway bar!
Allen S
18
Jul 29, 2014 10:16 PM
TiggersHHR
Feb 19, 2011 12:50 PM
DANSHHR
Apr 13, 2009 10:50 PM
RandyS
Mar 10, 2008 06:44 PM
